Is there a inline pump that can support big HP
Old 10-20-2008, 04:27 PM
Baltimore Whore
Mangled03gmc's Avatar
Default Is there a inline pump that can support big HP
Yah might sound dumb but I am just looking for a fix to this for NOW.. I plan to step up to a fuel cell, pump soon, but need a fix...
Thanks John
Old 10-20-2008, 07:02 PM
Baltimore Whore
Anbody??
John
Old 10-20-2008, 07:11 PM
magic's Avatar
how much HP?
Street or track?
I know the BOSCH 044 inline pump is good for around 700HP....then you get into the big dog pumps like the MagnaFuel or Weldon pumps....
Old 10-20-2008, 07:23 PM
Baltimore Whore
I am running a inline walbro 255 now and running out of fuel up top.. This just needs to be a quick fix till I can do the fuel cell... I don't have any hp numbers, but the 255 isnt cutting it...
John
Old 10-20-2008, 11:51 PM
James B.'s Avatar
I have had success dropping the fuel rail pressure from a 4-bar baseline to 3-bar. You've obviously got large injectors so chances are they were designed for a 3-bar spray pattern anyway. If you have enough capacity left in your injectors for a 15% increase in duty cycle this is an option for you.
Here's why this works:
A pump's volume decreases with backpressure. You've got a blower and run a lot of boost. If your baseline fuel pressure is 4-bar then that means when you get into high boost fuel pressure is exceeding 58psi by far, probably to just over 70psi. The more backpressure the pump is working against the lower volume it can provide.
In Corky Bell's "Maximum Boost" on page 95 there is a graph that plots volume (gal/hr) versus pressure (psi). According to this chart the same pump at 3 bar can deliver about 35% more fuel than one at 4 bar.
It sounds contradictory, but it isn't - less pressure = more fuel.
Old 10-21-2008, 03:01 PM
Baltimore Whore
James B thank you for the awsome input, prob is I don't do my own tuning, am not near my tuner. So it would take time to get another tune right, back to me.. I am looking for a bigger inline pump to get me by untill I switch to a fuel cell setup... Err this stuff has to be so difficult, lol at least for me hahaha... T T T
Thanks again
John
Old 10-21-2008, 06:59 PM
dirt track racer 81's Avatar
A1000?
Old 10-21-2008, 07:08 PM
phasemaster1's Avatar
Originally Posted by dirt track racer 81
A1000?
I think Spoolin runs this pump John.
Old 10-21-2008, 07:27 PM
Baltimore Whore
Ok thanks guys, I have been looking at them, WOW 300+ smackers, but ya got to pay to play... I am hopping I can hook this up inplace of where my walbro is now, then use this for my fuel cell set up aswell. I don't see what I couldn't
Thanks John
Old 10-21-2008, 09:27 PM
2nd fastest 5.3 ECSB
trever1t's Avatar
https://www.performancetrucks.net/fo...d.php?t=427323
jump on it!
Quick Reply: Is there a inline pump that can support big HP
