There is something wrong
11 Second Club
the idc can go that high. the idc can be that high but im not suppose to be leaning out like that even if the idc is 100%. im going to swap computers with my buddy to see if my computer is the problem and blow out the fuel line to see if something is stopping it up.
FormerVendor
Sounds to me like the tune is way out of wack. The WOT tuning needs to be done with a wideband, if not then its a guessing game as to what your AFR will be.
Even though they are not accurate at all at WOT what mv are your O2s reading at WOT?
Can you post your tune or a logged run?
FormerVendor
If you can post up your tune I can take a look at it and see if I see anything that would be causing you problems if you would like.
What AFR are you commanding at WOT? Are your VE and MAF tables dialed in?
11 Second Club
yea im just going to flash my tune into it.
yea i tuned the pe table with a wideband ill post up the tune. right now i just have the whole pe table set at one afr.
11 Second Club
here is the tune and also a log with the stock pump and it does the same exact thing with the aftermarket pump. the ve is pretty close i have the maf where its rich though.
FormerVendor
Woah that IDC is high! I didnt get to look over the whole tune because its on my laptop and i am at work right now and my battery died on me but i didnt really see anything that really jumped out at me yet in the tune itself.
You havent touched the injector table at all correct? The one thing that I do like to do in the PE enable is set all the map values etc... to all 0s to ensure that you dont have any kind of delay at all in PE but other than that and like i said i didnt get a chance to see everything.
I wonder if their is maybe something wrong with the regulator? Have you checked to make sure you dont have any vaccum leaks anywhere?
11 Second Club
