Thermostat
Thermostat
I DON'T PLAN ON A E-FAN UPGRADE UNTIL AN ENGINE SWAP.IF I JUST SWITCH TO A 160* T-STAT WOULD IT MAKE A NOTICABLE DIFF? WOULD I HAVE TO DO ANYTHING ELSE?(PROGRAMMING). BY THE WAY THIS FORUM HAS BEEN VERY HELPFUL ON ALOT OF THINGS,YOU GUYS RULE
Thermostat
Originally Posted by FarmTruc
Go for it, it's a an easy swap and you can use it with the other engine.
It'll keep your engine cooler and no need for a tune.
allen
allen
Won't the colder temperature tell the computer the engine is not up to temp. yet and continue with excess fuel.?
It's an easy mod, and its been pretty effective so far. I just did it last weekend and my truck normally sat close to 210*, now it sits a half a tick above 180*. I put the 160* stat in.
I don't think the computer stays in cold start mode, because the stat is open and circulating coolant throughout. Plus, 180* is a lot warmer than ambient (I hope), which is close to what your coolant is at upon cold start up.
Originally Posted by BLUE'03
What Is The Best T-stat To Get? Where To Get And How Much?
Go to O'Reilleys. Regular thermostats will be fine. They have regular 160 thermostats for about $3-$5. Don't spend $50 on a hypertech one (you are just paying for the name).
Originally Posted by OBXMarine
Go with the 160. The 180 didn't make a lick of difference in my temps. I run about 172 degrees now. Hypertech is the only brand I'm aware of. Several of the sponsers have them. Tbyrne and Thunder Racing come to mind.
Originally Posted by retsell
I was told that hypertech was the only one who made one for the ls1. It is 50 bucks because it comes with a new water neck as well.
I'd get the thermo if you plan on doing any serious mods. Lots of HP creates heat and keeping the motor even 10deg cooler on avg. can go a long ways toward thwarting detonation.
