Thermostat Debate!!!!!!!
#24
Originally Posted by gmforlife
I just look up in my PID's to see if i could log engine oil temp, doesn't have it. Can you log Enging Oil Temp with HPT?
#25
Originally Posted by treyZ28
You CAN, we just dont have an engine oil temp sensor, which is a shame. I'd trade oil pressure for oil temp any day of the week.
#26
Originally Posted by 2004Denali
when ever you buy a new T-stat take it home and put it in some water on the stove with a candy thermomitor, and than you can see exactly when it starts to open and when it is fully open
#28
High on diesel fumes
I usually just fill her up and go, and take a bottle of mix with me. Stop down the street, check coolant level, top off if necessary. Keep a close eye on coolant temps. Do that a few times till coolant temp stabilizes and check level again, them I'm good to go.
#29
So what is the best way to get all the air out of the system after replacing the Tstat? I hate how they have the cooling system on these things.
#30
PT's Slowest Truck
I've had good luck (on a few different manufacturers that are prone to air pockets), by squeezing either the upper and/or lower hose to "burp" air out of the system. I actually squeeze, hold, and sometimes shift the hose down or to the side. The reservoir will usually bubble and you can feel the coolant suck into the engine, then refill and repeat until the suction stops...it's kind of a "do by feel" sort of method that I've developed over the years that has given me about a 95% success rate.
