Thermostat question
Thermostat question
I just put the 180* thermostat in my truck and I was wondering something.
When I crank it up and let it set for a few minutes it won't go above 180*. That's good!
However, when I start driving, it goes right back to almost 210*. That's not so good!
It's that just the way it is, or did I screw up?
Josh Hucks
NXS Customs
Josh Hucks
NXS Customs
Re: Thermostat question
My 160 thermostat runs at 180 all day. I have always heard that the thermostate runs about 20 degrees warmer than what it is rated to open at. It does not cool the motor any better, it just opens sooner, which in turn keeps the motor cooler than letting the motor get to 215 to start cooling down.
13 Second Truck Club
From: Pueblo de Nuestra Señora la Reina de los Ángeles de la Porciúncula
When I installed the 160, I told my HPP3 that it was there. What exactly does it do? I think the booklet says it advances the timing??
[/quote]
Same with my 160. Stays at 180 all day. One concern of mine is that whenever I turn on the A/C, it shoots up to the 200 mark. Is that normal?
[/quote]
just done turn on the A/C!
[/quote]
[/quote]
**** that. It's 100+ degrees out here man! You drive around the valley with the windows down?
