thinking about 4.10s
Wearin' da big hat
![Grin](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_grin.gif)
I have 4.11s, they're not bad. Make sure you don't over gear, or make sure your tire size is big enough otherwise you'll run into bad traction problems or your truck will top out to quickly. It all depends on your powerband, expectations, cam and converter, etc etc.
Custm2500's Rude Friend
It says LS1 noob ![Grin](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_grin.gif)
![hmm](https://www.performancetrucks.net/forums/images/smilies/hmm.gif)
![The Jester](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_jest.gif)
If your running a tire taller then around 33 you may wan't to go with a higher gear.
We would also need to know if your on a stock motor with a stock tune or if it's modified?
