Thorley vs OBX
#62
#63
When I do decide to get my headers I will be getting a tune at that time also. I do have another thread started comparing higher ratio rockers vs a mild cam. What are your thoughts on the higher ratio rockers? As it would be much easier to install these vs a cam. I know in terms of power a cam would dominate the rockers. But if and when I do get a cam I would go mild anywase.
#66
The Thorleys come chrome plated or coated. I had the plated ones for four years in Michigan where we generously use salt in the winter. While the headers turned blueish, there was almost no signs of rust.
#69
I have the OBX headers on my 4x4 with no problems. I've had my y pipe out 4 times, and each time I put it back together the header was touching something. All you have to do is loosen the header bolts, and the band clamps adjust them where you want them, and tighten the band clamps, then the header bolts. You can make the sit anywhere you want like that. I've got 1/4" to the frame on the passenger side, and 1/2" to the stearing shaft, and 3/8" to the front ds. I didn't think it was that big of a deal.
AHelm3
04-08-2016 07:51 AM
Angry Silverado
10-21-2015 07:07 PM
