Those 03+ that went from V6 to V8
SPAM HUNTER
I used some self tapping screws...i just bent the original pedal tabs out of the way.
I want to switch to cable, i hate working on the engine and needed to idle it up and having to go into the cab...i also want to because i cant figure out the cruise control.
I was just thinking that we could take the cable one out and weld or bolt on a new one. IIRC, when i took the pedal off the truck with the electronic TB it had studs on the firewall, there was no bracket.
my work uses a stud welder all the time....maybe ill hafta do this wen i get mine in....i thought wen i looked under there a while back there were studs??? nd the wire gets routed through the cable hole to conenct to the module on the firewall?
yeaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa......sooooo i got fucked...my pedal is out of a nnbs...its the same as my dads 09 silverado! it has a bracket that makes it correctly mount under the dash also...
sooooo now i gotta go look for another one!
hirdlej
08-27-2015 10:22 PM
hirdlej
08-10-2015 10:51 PM
