Those running LS1-style injectors in here...
what about the pins? are they different. what about releasing the pins from the connector and putting the new connector on the factory pins. if the pins are the same then you can swap connectors back and forth without cutting anything.
otherwise i am gonna try and make my truck connectoors work with the l76 manifod. cutting my harness will be a last ditch effort
what about the l76 manifold setup frm scoggin dickey do thse injectors mate with the same style car connectors
has anyone been able to make their truck injectors fit with the l76 manifod yet? i know it can be done with the ls6
