Those running LS1-style injectors in here...
#23
with the L76 intake you will need different orings to use your car type injectors. I am still working out what else on the truck intake, I think it will just be o rings on the 42 marine injectors for plug and play in my application but I have not checked to see how the fuel rail will sit.
#24
what i was wondering is the setup from scoggin dickey comes with the rails and injectors all complete. do the car connectors plug into these new injectors?
#25
I went to the local Pick-N-Pull, found a V8 Aurora and got the entire injector harness for $5. All the wire colors matched up with my harness. I soldered and heat shrinked all the connections. It looks pretty close to factory and haven't had any problems.
A few pics: (they were a little big and I didn't feel like resizing so just click the links to view)
Connectors
Cut-up Harness
Finished Product
Connectors
Cut-up Harness
Finished Product
#26
Whipple496 has come up with the parts to make adapters for plug and play truck harnesses to LS1 style injectors. I got a set should be here tomorrow so I will be able to see how they work on my truck. (going with some 60's) He's fixin to put them on his truck this weekend. Might look into this if you really don't want to cut the stock harness.
#29
