Those of you with worked heads...
Whats up guys. I finally got my heads finished up they are 862's that have been port and polished, 6-angle valve job, and milled .30
Anyways... my question is once you guys have installed your heads, how long did you drive it untuned. I have a wideband, and an aeroforce so i will be able to keep an eye on EVERYTHING. Just curious how safe it is...
Thanks in advance
Thanks in advance
I slapped some ported heads back on december and still untune ! waiting to slap my street sweeper cam and tbss intake so i can finally tune it ! now and then my buddy slaps his sniffer wand to check if its running lean ! up to now it still fare!
Good to know! I figure between the wideband and the aeroforce i will be able to keep an eye on things. Im hoping with the bump and compression and better flow the truck will really wake up on the top end!
it should wake it up a good bit.. Mine felt a lot better with 1.5 points of compression more
Stainless Works
04-10-2016 05:34 PM
atxlt
07-21-2015 12:06 AM
Nimoryan
07-05-2015 04:50 PM
