Thought you guys would like to see this!!!
Old 03-09-2005, 09:26 PM
  #41
mattrem's Avatar
A older truck had traction control? I was wondering I know that Jeffs C5R build someone was making a special harness so he could use a bigger fly by wire TB on the Fast Intake.
Old 03-09-2005, 09:32 PM
  #42
Former Vendor
Speed Engineering's Avatar
Originally Posted by Flyer
ALl 03 and up are new style fly by wire TB's. The older trucks were only fly by wire if they were equipped with traction control. They were different types oif plugs, and the TB's did differ.
Same goes for SUV's as well.
Very well said. Mine has traction control. And therefor has electronic TB. I fact when i first got it. I had bought LS1 Edit and because these setups were so rare there was a TB limiter that took the guys at LS1 Edit about 4 months to find. They then updated their version specificly for a coupple trucks. Mine being one of them.
Sean
Old 03-09-2005, 09:35 PM
  #43
Former Vendor
Sorry the console is long gone. Your best bet is to have a local stereo shop build you a custom setup.
You can get the TB from SDPC and the connector. They faxed over the wiring diagram to convert it.
Sean
  #44
mattrem's Avatar
Is the front suspension still stock?
Old 03-09-2005, 09:37 PM
  #45
Former Vendor
Nope, It has 90/10's the sway bar is removed and for lowering it has a 4" Lower control arm.
Sean
Old 03-09-2005, 09:46 PM
  #46
mattrem's Avatar
Man that thing is going to fly, I think I am going to build a RCSB next. It will be next winters project. All the four link is your own design, like mounting points and everything?
Old 03-10-2005, 12:17 AM
  #47
Former Vendor
The actual mounting points for the four link is from Chassis Engineering, but we welded up all the bars and used a set of QA1 spherical ends. As far as the Coil over and panhard mounts we custom made those.
Old 03-10-2005, 12:49 AM
  #48
Green Thunder's Avatar
Looking good there Sean! Its been awhile since Ive seen yours, changed just a bit Looks like we will be seeing each other soon! Any pics on the DP?
Old 03-10-2005, 04:38 AM
  #49
if you build it(4 link) we will pay
Old 03-10-2005, 11:32 AM
  #50
Faze2183's Avatar
i still like the console
Quick Reply: Thought you guys would like to see this!!!
