thoughts on a 222/224 with a 112 lsa in a 5.3...
we put this cam in my brothers vett, 11.1-1 cr ls1 the power came in at about 3500, it would work real well with 4k stall. Unless you don't plan to run at the track with a sticky tire then a 3200-3400 would work fine. It lopes good too. Id put a 218-218 high lift 110 + 5 in it if were mine.
i am probably going to run a similar speced cam with less lift same duration in a rcsb 82 c10 with 4.11s and a 3200 circle d and tbss intake with all the bolt ons, have an idle clip or track times?
