Thoughts on exhaust setup
Recently had the idea to change my exhaust from stock manifolds and cats with a catback muffler to long tubes hi flow cats and a new muffler.
Not too familiar with this on Silverados, but for those of you who have done this before:
I planned on ordering a set of pace setter quick trip headers, the off road y pipe, two magnaflow high flow cats, and a moroso spiral flow muffler.
Will this all work, or does the off road y pipe delete my two cats?
Yes it does delete em I went that route but with a reversed summit glasspack then about 3 ft down a slp lm2 used stock piping then a 1 to 2 slp angled slash tip out the rt rear corner something like the dodge srt10s
Yesterday I got the idea to just run two pipes side by side instead of the y pipe. If I do it all custom I can allow for room for the high flow cats. I'll need two mufflers and a few angles and at least 2 or 3 clamps. I can use the existing hangers on the right side of the truck and then clamp the two pipes to each other. That should work perfectly because after the muffler I already have two pipes ran out for dual 45 degree exhausts out of the back of the truck. Thoughts?
