Thoughts on the Lingenfelter GT2 Cam?
#21
Originally Posted by Yelo
ICL and LSA CAN be the same.....but assuming that they ARE can cause you problems.....I never make that assumption, I ALWAYS like to know the LSA %100
The Lingenfelter GT2 is actually very similar to the Cam Motion cam I ended up getting (205/212, .548/.540, 114+4), though because of the wider LSA, it would have a little less peak power than mine, spreading it out over more of the usable RPM range.
For the price the LPE cam is a really good deal. The issue I ran into, and what eventually led me to getting a custom ground cam, is the advance. I knew I wanted a 4-5 degree advance, and with a custom cam I could install it dot-to-dot. With the LPE GT2, I'd have to install it using a degree wheel, and this being my first cam install, I didn't want to have to deal with advancing the cam myself.
For those more confident using a degree wheel, I would highly recommend this LPE cam. I have gobs more power all the way from idle on up to 6K RPM's. I'll get a review out next week.
