Thoughts of this set up for custom tune
14 Second Truck Club
91 Octane Tune
Rev Limiter 6000
1-2 Shift 5800 WOT
2-3 Shift 5800 WOT
3-4 Shift 5800 WOT
80% Torque Management Delete
Eliminate Speed limiter
Firmer Shifts
Save gas program
Tow/Haul mode adjust for maximum towing
Rev Limiter 6000
1-2 Shift 5800 WOT
2-3 Shift 5800 WOT
3-4 Shift 5800 WOT
Firmer Shifts
Save gas program
can you get that where you normally drive(no tow/haul) and have it as gas saving, and then when you put tow haul on, its a different tune? Like even normal w/o towhaul could be for 87 oct, and then towhaul could be 93 oct?
New set uo
Regular driving
Save gas program
91 Octane Tune or 87-91 dual octane. Which ever you think is better. I run 91 mostly.
Rev Limiter 6000
1-2 Shift 5900 WOT
2-3 Shift 5800 WOT
Firmer Shifts
Tow/Haul(performance mode)
Max Tuning
Hard shifts
100% Torque Management Delete
* or whatever you think the best setup is for max performance.
When I tow I will just swap to my factory PCM.
Does this sound good?
Save gas program
Rev Limiter 6000
1-2 Shift 5900 WOT
2-3 Shift 5800 WOT
Firmer Shifts
Max Tuning
Hard shifts
