Thoughts of this set up for custom tune
Old 07-12-2005, 11:03 AM
zippy's Avatar
5800 2-3
5700 3-4
100% torque management removal. if you want to go fast why the hell would you keep this.
shorter and better scaled shift timing
6200rpm limiter
etc., etc.
Old 07-12-2005, 11:16 AM
jerome's Avatar
will tq management delete kill the tranny after a while if you have no tranny mods?
Old 07-12-2005, 11:22 AM
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
Sure will! Killed mine after about 20 miles.
Old 07-12-2005, 11:34 AM
jerome's Avatar
so what tranny mods would let it handle 100% delete?
Old 07-12-2005, 11:40 AM
white1's Avatar
I'd definatly bring the rtev limit up around 6200 or so if the valvetrain is stock. Higher if you've upgraded springs, and have a cam that will still make power that high.
Old 07-12-2005, 11:47 AM
Coban's Avatar
Wait a minute. I was under the impression that tow/haul only affected tranny parameters. Some of ya'll are saying that timing tables are affected too?
Old 07-12-2005, 12:12 PM
I have to do the crank relearn since i put a whole new PCM in but the truck still drives fine. If you use your PCM to tune then you wont have to do a relearn procedure but if you put a new PCM in chances are you will have to either a security relearn, idle relearn or the crank relearn. You can do them all yourself except the crank relearn unless you have a scan tool for it. No big deal though
Old 07-12-2005, 12:14 PM
white1's Avatar
If you pull your pcm out and put it in another truck then put it back in yours, do you have to do a relearn?
Old 07-12-2005, 12:41 PM
zippy's Avatar
torque management may assist in taking a trans out. if you have the settings right though a mostly stock truck will handle it just fine. my boss has well over 30k on his truck and hasn't had torque management since around his first oil change. i've tried a large range of shift points on his truck and right now he's at 6000, 5900, and 5700. he's had not a single trans problem to date.
Old 07-12-2005, 12:53 PM
TXsilverado's Avatar
depends on your everyday driving how long your stock tranny will last. my tranny would be toast by now if i had 100% removed.
Quick Reply: Thoughts of this set up for custom tune
