Throttle Body Sticking
Old 02-24-2003 | 08:46 PM
BigKID's Avatar
Default Re: Throttle Body Sticking
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by creederado:
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by BigKID:
<strong> Now that the EGR is gone it shouldn't get as dirty now. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Did you just trim it or is it completely removed, from headers to intake? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Completely gone. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> I disabled it with edit and made some block off plates to cap off the holes on the intake and header.
For the main subject... I think the "lightly sanding" suggestion is a good idea. The tight clearance between the butterfly and the tb is what is causing the problem. Once a little carbon builds up on the inside of the tb it caused an even tighter fit which causes the sticking. But if you do decide to sand/polish it make sure to take it off first. You dont want to get any of the shavings in the motor. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old 02-24-2003 | 09:01 PM
parish8's Avatar
single digit dreamer
i don't think it is the egr that dirtys up the TB, it is the pcv system.
Old 02-24-2003 | 10:30 PM
eallanboggs's Avatar
Light sanding is the way to go. Of course the TB is off of the engine during this process. 200 0r 400 grit. Sand then check for binding then repeat. You can look for a clearance problem by holding the TB up to the light with the TB in the fully closed position. You can sand both the blade and the bore a little bit each. It shouldn't take much. If you have a build up of gunk on the TB you need to remove that first with carb cleaner then start the sanding process. Of course your EGR system should be removed while this repair is being made or you'll be working on it again in the near future.
Old 02-24-2003 | 10:51 PM
BigKID's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by parish8:
<strong> i don't think it is the egr that dirtys up the TB, it is the pcv system. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I beg to differ. The residue I removed was dry carbon sute (same as on your tailpipe <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> ). If it had been a wet, oily residue, I could see it being the pcv system.
Old 02-24-2003 | 11:44 PM
JSmith's Avatar
Mine had been replaced originally with the TSB also. At that time I installed a TB spacer and never had a problem again. Once I removed the TB spacer the problem returned shortly after. My uncle is a GM mechanic and said they also lightly file the edge of the butterfly as well as cleaning them with Goodwrench top engine cleaner. After I filed the butterfly on mine I've only had to clean it once. I think once I get Edit my EGR is gone too.
Old 02-25-2003 | 08:20 AM
IM LOWR's Avatar
When my throttle was sticking a dealership told me it was caused by a clogged fuel filter. <img border="0" title="" alt="[Roll Eyes]" src="images/icons/rolleyes.gif" /> DUMBASS!
Old 02-25-2003 | 07:40 PM
GoldenVelvet's Avatar
Dont get me wrong Im just looking for an excuse for puting on a big bore throttle body. Im aware of the tech bulletins and I know a simple cleaning would fix it. But why fix it if you can replace it with a High Performance part. So back to the question.
Dose any one know where I can get a bored other than the high dollar BBK??
Old 02-25-2003 | 07:43 PM
parish8's Avatar
check out the link, there is another guy that does them also, i think his name is shanon or something like that, do a search on TB in the external section
https://ls1tech.com/ubb/ultimatebb.p...;f=24;t=006763
Old 02-26-2003 | 07:56 PM
Thanx parish8 that was exactly what I was looking for. Now all I need is the taxman to be good to me
do you think its worth $140 or $180 of improvement over stock??
Old 02-26-2003 | 09:10 PM
Um, FYI, You can do this mod for about$20 bucks and an hour of your time, if you are mechanicaly inclined. All you need is a dremel, epoxy, some sandpaper, and a polishing wheel. I did mine if you need advice on how to do it i can help you.
J
