Thrust bearing, crank play 3/16" of play
I pulled my motor because it was untuneable, now that i have it down to the short block i noticed the crank has about 3/16 of an inch play sliding in and out. Im wondering if you guys think the thrust bearing went bad?
I'm gonna pull the pan today, the motor getting some forged parts, cam, heads for the turbo build I'm doing now. I just wanted to see if my unstable oil psi, and crazy KR could be from a bad thrust bearing. I will make sure to post up what I find in the oil pan latter. And about ballooning the converter this whole problem started at 1500 miles after putting the motor in I got on it and it feel on its face and never ran right again. O well going FI now already have the turbo Kit, 4l80e, and a few other goodies just hoping I have better luck this time.
I bought my 6.0 with 150k miles on it. Owner said it had low oil pressure, after i tore it down and inspected it, i found the thrust bearing was destroyed. Also destroyed the crank too. Had to buy a new crank. But there was also about 3/16 play, probably even more..make sure it didnt dig a groove in the crank where the thrust bearing rides. If so, you need a new crank
if it did I guess I'm just gonna have to build a 408
I'll post pictures of what I find tonight.
