Time to cam sonoma texas speed-228R anyone have it?
#21
.........................Varying Lobe Separation Angle.....................................
...............Tighten............................ ..............Widen
Moves Torque to Lower RPM..............Raise Torque to Higher RPM
Increases Maximum Torque................Reduces Maximum Torque
Narrow Powerband...........................Broadens Power Band
Builds Higher Cylinder Pressure............Reduce Maximum Cylinder Pressure
Increase Chance of Engine Knock........Decrease Chance of Engine Knock
Increase Cranking Compression...........Decrease Cranking Compression
Increase Efective Compression...........Decrease Efective Compression
Idle Vacuum is Reduced....................Idle Vacuum is Increased
Idle Quality Suffers..........................Idle Quality Improves
Open Valve-Overlap Increases...........Open Valve-Overlap Decreases
Closed Valve-Overlap Increases.........Closed Valve-Overlap Decreases
Natural EGR Efect Increases..............Natural EGR Efect is Reduced
Decreases Piston-to-Valve Clerance....Increases Piston-to-Valve Clerance-------------------------------------------------------------------------
Is this correct? I thought it was the other way around.
#25
But all I could swing was a brand new take out converter from a 06 4x4 from trever1T on here when I built the truck as pricey as it was getting so I kinda knew I'd have a handicap
I can't wait to see how this cam and a 3200 circle D stall will run.
#27
I know to get every last horse out of it the long tubes are the way to go. But for me it's just too much work and hassle to mess with going the LT route since everything is already done and in the truck and leak free. Had longtubes been available when I built it you'd be damm straight she'd be packin them
#28
11 Second Hall Moniter
ARC
57
02-21-2022 10:54 AM
jkarnes
09-19-2015 07:11 AM
