Time to cam sonoma texas speed-228R anyone have it?
Old 03-28-2012, 04:05 PM
  #21
PowellSixO's Avatar
.........................Varying Lobe Separation Angle.....................................
...............Tighten............................ ..............Widen
Moves Torque to Lower RPM..............Raise Torque to Higher RPM
Increases Maximum Torque................Reduces Maximum Torque
Narrow Powerband...........................Broadens Power Band
Builds Higher Cylinder Pressure............Reduce Maximum Cylinder Pressure
Increase Chance of Engine Knock........Decrease Chance of Engine Knock
Increase Cranking Compression...........Decrease Cranking Compression
Increase Efective Compression...........Decrease Efective Compression
Idle Vacuum is Reduced....................Idle Vacuum is Increased
Idle Quality Suffers..........................Idle Quality Improves
Open Valve-Overlap Increases...........Open Valve-Overlap Decreases
Closed Valve-Overlap Increases.........Closed Valve-Overlap Decreases
Natural EGR Efect Increases..............Natural EGR Efect is Reduced
Decreases Piston-to-Valve Clerance....Increases Piston-to-Valve Clerance-------------------------------------------------------------------------
Is this correct? I thought it was the other way around.
Old 03-28-2012, 04:42 PM
  #22
FormerVendor
KLUG'S SS's Avatar
That information is accurate.
Old 03-28-2012, 05:06 PM
  #23
Damm about the time I think I know all the acronyms I find another.. Que es DCR
Old 03-28-2012, 05:17 PM
  #24
Mod with training wheels
smokeshow's Avatar
Dynamic compression ratio
Old 03-28-2012, 05:25 PM
  #25
I'm surprised in such a small light truck you think a 6.0 with the z06 cam has no low end. TBSS have plenty of giddy up off the line, but they're running a higher compression. Do you currently have the stock stall in there?
I have been outran by hondas from a dead stop till I can get some rpm then when the cam wakes up it's bye bye. My truck likes a 40MPH roll race from 2nd and it's scary.
But all I could swing was a brand new take out converter from a 06 4x4 from trever1T on here when I built the truck as pricey as it was getting so I kinda knew I'd have a handicap
I can't wait to see how this cam and a 3200 circle D stall will run.
Old 03-28-2012, 08:32 PM
  #26
chevysten's Avatar
I have a similar cam and a Yank 3600 stall in my S10 and it gets out the hole really good.Actually I've benn thinking about going bigger in my 5.3.And yes long tubes will help alot.
Old 03-28-2012, 09:14 PM
  #27
I know to get every last horse out of it the long tubes are the way to go. But for me it's just too much work and hassle to mess with going the LT route since everything is already done and in the truck and leak free. Had longtubes been available when I built it you'd be damm straight she'd be packin them
Old 03-28-2012, 11:07 PM
  #28
11 Second Hall Moniter
AKlowriderZ71's Avatar
You see, the thing about this cam is, it shines up top. That's where you need the advantage of headers over manifolds. If you really WANT to keep manifolds, you should look for a different cam. IMHO.
Old 03-29-2012, 08:54 AM
  #29
Lil brother PI's Avatar
it is a nice cam i would get the 110lsa of it has been working bad *** for some of the guys down here
Old 03-29-2012, 05:17 PM
  #30
FWIW I have the sanderson shorty s10 headers.
ARC
57
02-21-2022 10:54 AM
OHsixLS3
12-27-2016 09:30 AM
jkarnes
09-19-2015 07:11 AM
Ammadien
07-22-2015 08:50 PM
GRRR65GTO
07-10-2015 08:27 PM
Quick Reply: Time to cam sonoma texas speed-228R anyone have it?
