time to order just a couple questions
Old 07-29-2012, 07:21 PM
WICK3DxGATA's Avatar
Default time to order just a couple questions
okay so i am finally ready to order all of my parts.
but i have a couple questions to ask before i order all of the stuff.
first off i will say my truck is a 99 gmc sierra 5.3 z71 with a 4l60.
at first i was planning on going with the ht1 cam but i have decided instead to go with the tr220.
With the first cam i was told that i need this list of parts.
ls7 lifters
GM Performance Parts 12499225 - Lifter Kit, Gen III Engines, Set of 16 | SDParts - 1-800-456-0211
ls6 springs
GM Performance Parts 12499224 - Valve Spring Set, GM LS2, LS3, LS6, Set of 16 | SDParts - 1-800-456-0211
7.400 push rods
Manley Performance Parts 25735 - 7.400 Stock Length LS1 Manley Pushrods | SDParts - 1-800-456-0211
double roller timing chain
N Motion LS2/LS3/L76/L92 Double-Roller Timing Set
okay so first i would like to just make sure these are all of he right parts that i need and if anything else is needed.
i already have me a pair of headers there shorty but i got them as a gift so they will have to due for the time being.
next i would also like to ask what size stall would be good for this set up.
so if i could please get some responses it would be great i really want to order everything by this weekend.
Old 07-29-2012, 07:27 PM
Resident Retard
BlackGMC's Avatar
If your doind lifters you need to get haedgasketa and head bolts. If your going that deep might as well do lifter trays too
Old 07-29-2012, 07:33 PM
thank you.
would you mind if your able to get me a link for some good ones to use
Old 07-29-2012, 08:27 PM
N/ALS1's Avatar
If i were you I would try to sell the shorties and get a set of longtubes, pacesetter have nice ones that are really budget friendly. I felt a big difference from the JBA shorties to my pacesetters Lt, really nice. If I had the extra cash at the time I wouldve got the Stainless works.
Old 07-29-2012, 09:19 PM
13 Second Truck Club
grey matter 04's Avatar
Buy new lifter trays $35
And GM head bolts $80 unless you go arp they $100 or lil more
Don't skimp on the important stuff !
Old 07-29-2012, 11:54 PM
fix-it man's Avatar
In for info, looking to do a tr220 swap on my 5.3 as well...
Old 07-30-2012, 05:15 PM
anybody else? i really would like to order everything here soon. i could use as much advise as possible.
Old 07-30-2012, 05:36 PM
MASS seller approved
Petey62782's Avatar
? Is how many miles are u at? If u are over 100k then I would add some things like valve stem seals, updates timing chain, new water pump, and just because u are at it already with the lifters and the heads are coming off then update the valley Pan to a LS6 style with the oil baffle to help stop oil in the intake . Just my two cents. Because u will already have the accesorys off and those parts most of them will go sooner then later
Old 07-30-2012, 06:01 PM
Truck Sponsor
Sales3@Texas-Speed's Avatar
I would recommend at least lifters, lifter trays, and I would look into an oil pump as well.
Old 07-30-2012, 06:06 PM
AndysC3's Avatar
no need for the double roller timing chain. The LS2 chain will work great. valve stem seals, oil pump. And I would not run the TR220 with LS6 springs. but thats me.
Quick Reply: time to order just a couple questions
