Timing Chain!
Here you go MR.X....Cloyes makes one and you can get it from Summit. It has a .005" tighter centerline than GM's set. I checked their online catalog and could not find it. But I have bought one from them before. Comp Cams offers one also but I believe it's the Cloyes repackaged with their name.
Originally Posted by Hit Man X
Cool! Do ya have a part number? Should I just give Summit a ring at 800-230-3030 ?
Did more searching...yay. This is the timing set ---> CLO-9-3153A and this is the chain for it ---> CLO-9-4194
The chain is $27, gears are $137.
WTF is this setup ---> CLO-C3210 ??? "Heavy Duty (X) = 3 Keyway" Is that an adjustable chain also?
I did some more checking also. The part number you want is 9-3153AL. The L makes sure you get the new improved chain (severe duty) along with the billet gears. Number C3210 is just a heavy duty set which has cast gears. Don't know if it is adjustable or not.
MorePerformance lists the 9-3153A for $149. They may have the 9-3153AL also but I don't know at what price.
The 9-3153AL is $360! I can't drop that much for a timing set. The 9-3153-A comes without a chain... and is like $135 from Summit.
