timing chain play
timing chain play
hey guys just putting in a new cam in my truck and was wondering how much play you can have in the chain and be alright.my truck only has11000 miles on it and didnt want to mess with the oil pump if i didnt need to but the stock chain seems sloppy.by the way the cams specs are 214 220 .579 .580 on a 114+4.thanks alot
If you put a new chain it will be loose again in 100 miles. Besides, the new chain is not going to seem much tighter. Just the nature of the beast. At 11k your old one should be fine.
Which springs are you going to use?
