Timing gear help.
Timing gear help.
Could someone tell me the exact way to line up the timing gear? 6-12 dot to dot ? intake stroke , compression stroke? Heard 10 different ways from 5 people lol.
It starts fine, yall do it on the compression stroke?I'm having a tapping that gets louder/faster with throttle. Also my tuner said he had to add 200% more air to get it to idle, an it is chugging 260 cranking compression...cam is a 228/236 588 578 111+4, has 862s ported an milled .030, 7.4 pushrods.
When you put the timing gears dot to dot this puts #6 at tdc of the compression stroke, and #1 at tdc of the exhaust stroke. When they are facing away from each other then #1 is at tdc on the compression stroke and #6 is at tdc on the exhaust stroke.
