TNT Power ring + FIPK2
Old 07-15-2004 | 02:21 PM
TigerFan187's Avatar
Default TNT Power ring + FIPK2
Is anyone using the TNT power ring with a aftermarket air intake like the FIPK2??? Does anyone know what it takes to make this setup work? I figure I would ask before I tried. I just hope it doest require E-fans because I didnt plan on getting those for a few months!!!!!!!!
Old 07-15-2004 | 02:26 PM
Looney102's Avatar
how thick is the power ring??
Old 07-15-2004 | 02:58 PM
bdubb's Avatar
Not sure but it adds somewhere between 2.0 or 3.0" in front of the TB.
Old 07-15-2004 | 03:09 PM
mudz5.3's Avatar
I know the UPD would be impossible with the power ring, so I can imagine that the fipk2 would be too. Go get them e fans!!.
Old 07-15-2004 | 04:28 PM
Deckhand's Avatar
anything 1 centimeter more would cause the intake tube to hit the fan shroud.
I need some efans as well.
Old 07-15-2004 | 05:19 PM
SH*TBALLS!!!!!!!!!!!! Well I just found out the guy that is gonna do my install has done several and says its possible and I will be seeing him tonite so I can ask him as well!!!! There is maybe 1/2 inch to the fans and I guess he is gonna trim down the side that goes in the TB!!!!!! I know that there are a couple of F-body guys that disassembled the Power ring and Drilled in the TB and the other drileld into the intake tube! I already have about a $1000 list and I hope I dont have to add another $400 for the E-fans! What about the LS1 fans?????????????????? Anyone????????????????
Old 07-15-2004 | 05:21 PM
mudz5.3's Avatar
LS1 or LT1 fans would work just fine. You could run them manuallly until you get the updated pcm from Allen.
Old 07-16-2004 | 08:38 AM
bdubb's Avatar
I ran the LS1 fans with my TNT kit.
Cammed4ever
08-20-2015 10:47 AM
Dezert1500
07-30-2015 02:51 PM
Gadgetized
07-18-2015 02:15 PM
1320Chicken
07-14-2015 10:58 PM
Quick Reply: TNT Power ring + FIPK2
