TOG headers or ASM headers
Go with togs if yu want a easy install.My azsm lt were a mother@##$%^ to
install.The passenger side alone took hours,to install.But i think if yu are 2wd its alot easier.As far as power goes huge diffrence in torqe up to 4000 rpms.MY truck got quieter after header install
.And tog headers are midlength headers..
![EEK !!](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_eek2.gif)
Yeah, TOGs are considered midlengths but they are EVER so slightly shorter.
TOG build quality is considerably better than ASMs to me. Thicker flanges, thicker tubing, and a lifetime warranty.
11 Second Club
I like the ASM's better, and they aren't hard to install. Driver side has no obstructions at all. Remove your intake tube and heat sheild below the evaporator, and the passenger goes in with out any problem. I ground off the tab on the steering shaft, but it wasn't needed. The Togs have a thicker flange, but the flange on the ASM's is pretty thick as well (more than enough).
where can you get togs headers, is the price similar to asm's long tubes would make more power, not enough to tell a difference between the two. im in that same delima also.
Tech Fanatic
I love my ASM's. I havent had any problems with the coating and I think the build quality is excellent. The install wasnt especially easy but no where near as much work as my hotchkis springs and edelbrocks.
The torque and hp increase was definitely noticeable throughout the whole rpm range.
Superman09
09-25-2015 05:55 AM
5.3lSilverado
09-20-2015 06:48 PM
