Toluene or Xylene question
Originally Posted by Black_Silverado_5.3
Ethanol (Ethyl Alcohol, Reagent Alcohol, Grain Alcohol, EtOH) has been the topic of many automobile researchers in the sense of using its two higher blends, E-85 and E-95 as fuel...Alcohol, Dehydrated Absolute is 200 proof and contains a flash-point of aprox. 13.5 degrees Celsius (57 degrees Fahrenheit). There is this other one in which ethanol is made into an ether: ethyltertiary-butyl ether (ETBE) in which its properties can be used to make oxygenated gasoline...I don't know if this will work because it will reduce the volatility of gasoline...you decide...Now Methanol (CH3OH) shares similar properties with ethanol...Its former name was "Wood" Alcohol...why? well, it's obvious...Anyways, it is used to produce the oxygenated Methyltertiary-butyl ether, which is no other than the gasoline "cleaner"...Xylene (Dimethylbenzene, Xylol...etc.) has a flash point of about 156 degrees fahrenheit, and automobiles run at slightly higher temperatures....so it don't know guys, if you want some true performance just use some solid jet fuel with ammonium perchlorate as the oxidizer...that'll give you some good boost....laterz...
SLA
ps: sorry about the long paragraph...i just like to share stuff like that...
SLA
TAPyvehc93
09-12-2015 08:19 PM
