Toning down 4" exhaust
So, the 4" pipe going over my rear axle didn't work out with the drop I have out back. Pipe kept banging on the axle on larger bumps.
So today I hacked off the pipe just after the muffler exit. It's the 24" Magnaflow diesel muffler. Outside the truck doesn't sound any louder, but it drones like mad in the cab now and frankly gives me a headache. Would a turndown after the muffler do any good? Or do I need to look at a different muffler? I miss my Corsa catback. I'd err on the side of quieter sound, as honestly, I much more prefer listening to the turbo sing than loud exhaust.
Baltimore Whore
The droning sound. It will be there untill you exit the pipe other then under the bed.. 4'' in it self is going to have droning issues because of the dia of the pipe itself..You could possibly add a dynatech turn down tip, it seem to cut down slightly on my drone, rasp issue. I since switched to that huge Edelbrock muffler, the rasp and alot of drone is gone, but not all of it. Your 4'' exhaust is already hushed some because of the turbo..
I had a single 5 inch all the way out the back when i got my truck and there was no conversations while accelerating. Drone like crazy above 2000 rpms even though it went all the way out the back
He already said over the axle didn't work because of his drop. Is there any space before the muffler to run a resonator or another muffler? You could add a 90* bend after the muffler to make it a side exit before the rear tire. That should help with drone a little.
