Toning down 4" exhaust
#23
Haven't taken a look at it yet, but my problem as has been pointed out in this thread, is the fact that exhaust is exiting under the bed. I've been doing a lot of brainstorming....from turndowns, to flexible exhaust tubing, to different mufflers, to oval exhaust tubing, etc. I'll update when I come to a solution. Whatever it is, I want to maintain the exhaust area provided by 4" tubing.
#26
I have a gauge for that
Yes. And before you say you cant go over the axle like I did, keep in mind even though mine is still pointed at the ground under the bed it is so much quieter now than when it was just pointed straight back. Also the area of a 4" pipe is about 12.5 sq inches, and dual 3" is about 14.14 sq inches.
#27
Thats the point, theres more to it than the length of pipe. Even the acoustic dynamics are different given the proximity of my bed to the ground versus yours. When I had the pipe over the axle and exiting by the spare tire there was no drone, it was great. In that picture of your setup mentally flip the axle over the leafs and imagine the clearance to the pipe.
Donaldson makes a plethora of big mufflers that Ive been checking out and they're cheap to boot. Im just not sure if i want to do a turndown right before the axle, id be weary of drone. Magnaflow has a 22" 4" inlet dual 3" out muffler but it has a 2.5" core. Dual 2.5s would be a roughly 27% decrease in area versus the 4", with dual 2.75" being pretty close and dual 3" exceeding a single 4" in area.
#28
If you wanna bring the truck up some time, maybe we can figure out something that will work. I've got TONS of scrap tubing and bends I'll give you and can fab something up for cheap! Maybe a 4" turn down/kickout and a resonator tube to kill the harmonics will be the ticket. Exhaust noise/drone is a HUGE petpeev of mine! Just let me know
#29
On this topic what would y'all think of a dual 2.75s after my 4" magnaflow flow wise? The 30" magnaflow has a 3.5" core so that is the smallest point in my exhaust so would a a split to dual 2.75" pipes become the next restriction or would it even make a difference.
