Torque converter bolts??
How do I change this text
I just ordered my new 4l80e trans and conversion kit. I also ordered all the needed hardware for the conversion. I will be running a 4l60e torque converter. (with the three bolts). Is the three bolts going to be strong enough??
I certainly wouldn't.......that's the only connection between the engine and transmission and I'm pretty certain that three 7/16" bolts aren't going to hold the power of a boosted motor very long
Yup they will if Allen's tranny bolts are holding up to the horsepower he is making then it will work just fine for you.
I still have time to change my order, But I was told by sells at Speed Engineering, that three bolt would be fine. (they have a 800+hp car with 60e converter) I just wanted to hear some other thoughts on it.
1-7/16 grade 8 bolt has a shear strenth of 10680 lbf at the threads (http://www.hobson.com.au/class_8.htm), so I would think that the bolts would not be the issue. Most likely the flex plate would brake before the bolts, but I think with you power level, you would be fine with 3 bolts.
BennyB
08-01-2015 08:48 AM
KyleW707
07-29-2015 08:17 AM
