Is this a torque Convertor Drain?
10 Second Club
If you take this metel cover off what is under it?
Does it have a drain for the covertor if you take it off?
Alot of the ford tranny have this then you can rotate the engine until you see a drain plug...
When I installed my tranny, I used that access hole to push the converter back, spin the converter and also to spin the FP when bolting it up. I also used the smaller access hole a little farther back to push the converter up to the FP once I was ready to bolt the converter up.
Cammed4ever
09-30-2015 03:38 PM
lxcoupe
09-25-2015 12:36 PM
