towing cam for the 422?
Old 10-13-2004 | 08:03 PM
RED2K's Avatar
Default towing cam for the 422?
The cam in the 422 i bought from Silent1 is like 246/249 612/620 on 112ls and I bought a cam from stopyify that is a bit smaller. I still want this to be able to pull my 18ft all steel trailer, racecar and about 1200 lbs of tire, tools, generator, and air tanks and such. What cam would I be best with. I want some bad *** low end torque. thanks in advance.
Old 10-14-2004 | 06:01 AM
RED2K's Avatar
ttt.............................
Old 10-14-2004 | 08:41 AM
mudz5.3's Avatar
I'd say the smaller one. What are the numbers?
Old 10-14-2004 | 10:48 AM
RED2K's Avatar
i WAS KINDA THINKING MAKING IN THE 226 228 DUR RANGE
Old 10-14-2004 | 01:49 PM
Chris@AP-Engineering's Avatar
Under criminal investigation for fraud
You are going to want to go with something in the 220's for duration. That should give you killer torque and make towing simple.
Thanks,
Old 10-14-2004 | 03:59 PM
marc_w's Avatar
I saw a dyno somewhere of a 224/224 in a 427(I believe), and people were calling it "undercammed" and a stump-puller. The HP seemed to peak just over 6K, with massive torque everwhere. You might want to cruise through the dyno archives to see what kind of powerbands people are putting down with their cams in similar motors...
Personally, my N/A goal would be a 408 with something small, big split, .6" lift, and tight LSA - a bigger version of what I'm running now - just not sure on those exact numbers. I'm after the same powerband as you though.
Old 10-14-2004 | 10:27 PM
RED2K's Avatar
I made up my mind and said Fu*^ it. Keep the big nasty in it and buy a another truck to pull the race car with. I think I wil try to find a high mileage older cummins 3/4 ton to pull with. I guess since I have this 422 I might as well go all out. I think I might have to treat it to a PI 3600 now. I got spanked by a 03 cobra tonight and it made me see the light
Old 10-14-2004 | 11:35 PM
mudz5.3's Avatar
Join the club. I think you should buy a cobra instead! j/k I still drive my truck from time to time. I like it but just way too much into the turbo, gotta love boost.
Old 10-15-2004 | 06:52 AM
zippy's Avatar
with that many cubes even the big cam will be a nice puller. it doesn't take that much torque to pull a moderatly heavy trailer down the road. if a s**t torque 4.8 can do it your nicely cammed 6.9 can do it just fine.
Bluecollar Hotrods
06-11-2024 11:37 PM
Oobray
06-13-2022 03:38 AM
2500ZL1
01-25-2016 06:30 AM
Dirtywhite
08-05-2015 04:10 PM
Aboss
07-09-2015 10:28 AM
Quick Reply: towing cam for the 422?
