Toyo Proxes S/T
Toyo Proxes S/T
I am thinking of purchasing some Toyo Proxes S/T 275/60/16 to replace some Michelin LTX M/S 265/70/16. I have searced and saw that several people have tried the Toyo on the stock aluminum rims with no problems mounting just wondering about the longer term effects that you have experienced with regards to wear. Thanks to everyone for your input.
2001 Silverado SCSB 4.8L K&N, Flowmaster, HPP3, Yank 3000, 3.42 G80
Re: Toyo Proxes S/T
I can't comment on the longterm effects for the toyo's but I can comment on the tires. The Toyos makes my truck track alot better at higher speeds & traction is better than the stock General tires I had on them before & they also look alot meaner. They are about an inch smaller in diameter that the stock tire, just barely noticible.
Re: Toyo Proxes S/T
I have a set of 255/55/18's on my Americans. I don't spin as bad, but maybe because I have a 4.8 pushing 18's! No seriously, they are good tires, but make sure you have a good alignment.
Josh Hucks
NXS Customs
Josh Hucks
NXS Customs
KINGCYCLES
10-02-2015 10:21 AM
