TR 220 cam is in and doing well...
Old 04-23-2004, 10:07 PM
Gustin's Avatar
Default TR 220 cam is in and doing well...
This was done on my 2002 Z71.
I thought I would try this cam over the ZO6 cam instead for you guys ZO6 cam is to popular. The install went great, only took around 4 hours. Driveability is great. Nice lope at idle. I have to delete P0300 (misfire) code tomorrow. Also, I had to drill out the TB to get the IAC counts back down to 30 with A/C off. When I first started the truck the IAC counts were around 105 with the A/C off. Must bump the idle up to 650 or 700 rpms. I might be able to dyno the truck tomorrow as well.
Mods so far:
TR220 cam on a 112 lsa
ASP underdrive
K&N FIPK
Mezier electric water pump
Electric fans
AS&M headers (!CATS)
Gibson cat back
Billet servos
Transgo shift kit
4.10 gears
Rancho 4 inch suspension lift
16x10 Classic 2's
MT 33x11.5 tires
Tahoe grille with putco speed inserts
Sir Michael's rollpan
This monday the Yank TT3000 is going to be installed.
I will come back with more results.
Thanks,
Sean
Old 04-23-2004, 10:09 PM
04sierra's Avatar
Sounds nice! Let us know any dyno #'s.
Old 04-23-2004, 10:18 PM
14 Second Truck Club
Awesome, let us know how everything works out!
Old 04-23-2004, 10:34 PM
FILE's Avatar
Awesome.. I also have that PO300 code I need to take care of.
Old 04-23-2004, 10:41 PM
Flyer's Avatar
Instead of deleting the code, you should multiply the low/idle rpm misfire tables by 200% until you don't get anymore misfire codes.
Old 04-23-2004, 11:16 PM
2001si3rr@'s Avatar
I agree; you really shouldn't just delete the codes.
What are the specs on that cam you installed?
Old 04-23-2004, 11:40 PM
F8L Z71's Avatar
Should work quite well.
I'm guessing 320-330rwhp with your setup
Old 04-23-2004, 11:45 PM
Flyer's Avatar
Another reason to adjust the tables .... If the PCM sees to many misfires, it won't lock the converter. Editing those tables will decrease the misfires it sees.
Old 04-24-2004, 06:30 AM
99Silver6.0's Avatar
Flyer,
Thats good info! Im gonna go that route. Which table do yo have to edit?
Old 04-24-2004, 11:33 AM
Flyer's Avatar
Low RPM and idle RPM ... they are in the engine diagnostics bit.
Quick Reply: TR 220 cam is in and doing well...
