TR-6 or TR-55 for a 11.0:1 CR 8.5+DCR NA setup???
Old 06-06-2011, 04:13 PM
Resident Retard
BlackGMC's Avatar
hmmm, well this is odd, cause summit racing says a TR6 is a heat range 6, a TR55 is a heat range 5, and a TR5 heat range 5....
TR6
http://www.summitracing.com/parts/NGK-4177/
TR55
http://www.summitracing.com/parts/NGK-3951/
TR5
http://www.summitracing.com/parts/NGK-2238/
Old 06-06-2011, 04:15 PM
Resident Retard
BlackGMC's Avatar
oh nevermind, i just reread what your wrote.... I am talking TR55 vs TR6.... not a TR5 vs TR55.. But a TR6 is a colder plug than TR55....
why did you bring up TR5???
Old 06-06-2011, 04:19 PM
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
Colder plug will get your more timing
Good read on plug selection
http://www.carcraft.com/howto/116_07...eat_range.html
Old 06-06-2011, 04:29 PM
Truck Sponsor
Wheatley's Avatar
I would personally start with a NGK BR6EF,read the plugs properly and go from there.
The plugs will tell you what the engine needs/wants
Old 06-06-2011, 04:38 PM
11 Second Truck Club
fastrt's Avatar
I ran those in my 5.3 H/C/I 10.6:1 with a 100 shot. ran damn good. I think N/A I would run TR6 cause it puts the spark out in the combustion chamber farther than the br6ef no-projected plugs. On the bottle, deff go BRxEF plugs. The BR6 is special order plug most times.
True, thats why the TBSS guys run them n/a
Old 06-06-2011, 04:55 PM
Truck Sponsor
Wheatley's Avatar
Yes they are a good nitrous plug,I run them N/A also,does very well and everything looks great.
The main thing to do it read the plugs and look at what the are telling you.
Old 06-07-2011, 07:41 AM
krambo's Avatar
I daily drive this plug N/A with my 408 and the engine really seems to like it over any other plug. If I know I will be spraying a small shot, I throw the BR7EF plugs in and daily drive those which seem to do just fine as well. My engine will slowly develop an off idle misfire with B8EFS or B9EFS plugs (after about a hundred miles from new) if I attempt to daily drive them. I can tell a difference in N/A power (lower) with the 8's and 9's but they are really just for the bigger shots of nitrous, not a N/A plug for my application...too cold, can't burn off any deposits leading to misfires.
The recessed plugs seem to perform a little better with the LS6 heads in my N/A application over the projected tip. This is totally my opinion and based only off of SOTP testing.
BROKE-aSS-BLAZER
10-13-2017 03:50 PM
Gadgetized
10-22-2015 09:06 AM
GMCtrk
18
10-06-2015 03:48 PM
blackedoutchevy22
10-01-2015 08:07 PM
StrokeTheLS
09-29-2015 08:33 PM
Quick Reply: TR-6 or TR-55 for a 11.0:1 CR 8.5+DCR NA setup???
