tr224 vs tsp 224r vs tsp 228r
#21
Nice! Let's be honest here though, you have more compression and better heads. So I'd expect you to make 10-20 more hp. TSP's dyno testing showed that the 228 made 6 rwhp more than the 224 with little to no sacrifice in driveability.
I'm going to use the SDPC springs and TSP pushrods, LS2 timing chain, and will reuse my stock oil pump.
#22
11 Second Truck Club
#23
I look at it this way, I can always add a stall later down the road. This truck had a 4.8L and 3.42 gears for 143k miles, whatever I do it's not going to be worse of a pig than that! The way I drive doesn't really lend itself towards a stall anyways. I like a very stiff throttle and usually drive like an old fart most of the time. How else can you explain the fact that my stock 60e is still working perfectly?
#26
sorry to threadack, but i hate starting cam threads.
What exactly is advancing? what advantages /disadvantages is caused by this, and more importantly how do you do it when you install a cam.
I also just bought a tr224, should be going in by the end of february with some cut outs, and a good tune.
#30
i plan on keeping my stock 3.73's and wont be able to afford a tc for awhile. Advancing the cam sounds like agood idea for me..how many degrees should i advance mine when i install it?
jtphelps289
09-29-2015 12:00 PM
