TR6060 onto BBC??
A transmission spacer around 1/2" thick. Also call a good torque convertor company to see if the stock convertor will fit into the crank. You may need to widen the holes in the flexplate. You will also need a transmission controler either with an engine mangement system like big stuff 3 or a standalone unit from tci.
hannes_slanec
04-15-2009 07:27 PM
