Traction issues
Old 01-04-2004 | 02:14 PM
13 Second Truck Club
From: Pueblo de Nuestra Señora la Reina de los Ángeles de la Porciúncula
Originally Posted by XLR8NSS
Yeah, with 30" tires go for the 4.10's. That gearing is still better than what a stock Fbody runs as far as cruising rpms. I think a 3800-4000 stall with 4.10's would be a killer setup for impromptu roll races. The midrange-top end pull would be KILLER.
True, but I think he wants to be able to hook off the line....
I know with my 4.10s, 3200stall and posi I get NO traction from a complete stop....haven't you guys seen my video?
If you like running from a slow roll however (20-25mph) then get my setup, my **** pulls hard with no slipping....
Old 01-04-2004 | 02:21 PM
XLR8NSS's Avatar
Adkoonerstrator
Believe it or not, higher stalls are easier to launch off the line than tight stalls.
Unless you have some exstensive suspension mods neither will let you just punch it off the line but, the higher stall will let you roll into the throttle harder without blowing the tires away. I don't know how to explain it exactly but, from experience it's true.
I had a 3200 stall and 3800 stall in my Camaro and the 3800 was much nicer on the street from a stop and roll. I could roll into the throttle hard with the 3800 and not smoke the tires while anything over 1/4-1/3 throttle with the 3200 seemed to spin'em.
WILWAXU or Ragtop 99 could probably explain it better if you ask in the Transmission section.
Old 01-04-2004 | 02:25 PM
XLR8NSS's Avatar
Adkoonerstrator
It's ashame BFGoodrich doesn't make a drag radial our size because those bastards will hook anything on the street. My brother in laws big block 4spd 67 Chevelle hooks like crazy on some narrow a$$ BFG drag radials. It's crazy. They spin for a little bit but, when they get hot it's all over but the crying.
Old 01-04-2004 | 02:26 PM
I understand why that would be true, but I don't think he's going to go with a 3800
That's why I suggested he keep his higher gears and get a 3000 stall
Old 01-04-2004 | 02:29 PM
XLR8NSS's Avatar
Adkoonerstrator
I think he should go with a 3800 stall. Oxidizer is running a Vig4000 or something like that if I remember correctly.
Old 01-04-2004 | 02:33 PM
ThunderZ28's Avatar
12 Second Club
chingon what size rims do you have?
what size tires?
do you have any side wall?
if not this may be your problem. no side wall = no wrinkle effect. try a set of slicks and see how it hooks with your 4.10's then. i bet you will be amazed at how well it will lauch with those.
on mine i have about 4-6 inches of side wall and i run on about 25lbs of air in the tires.
Old 01-04-2004 | 02:38 PM
Black Blown 02's Avatar
I think so too! A 3800 stall kicks ***!
Old 01-04-2004 | 03:13 PM
Heh..hell yea
I believe Oxidizr has a stock 5.3, transgo and servos, 4000 stall, cooler, and ASMs...oh yea...and nitrous
He had to change his rear tires to slicks to smack down that Viper though
Old 01-04-2004 | 03:15 PM
what size tires?
I have 275/45/20 all around.
I don't believe they make street slicks for 20s. Biggest I think is 18s.
I'm either going to go to dr's or get a higher gear like 3.73 or 3.42
Old 01-04-2004 | 06:29 PM
KeukaZ71's Avatar
i agree with Chingon, going to 4.10's w/ a 3000< stall will suck due to no traction, unless you have slicks or something. plus traction is already an issue with your setup. when you swap out the open diff and put in posi, it will not 100% cure your traction problems. you still turn tires loose with posi. again look at chingy's vid
Idryfly5
09-02-2022 08:55 PM
TAPyvehc93
09-14-2015 01:22 PM
dselby25
09-11-2015 05:03 AM
MA$TER_E
09-09-2015 03:14 PM
Boyes50
09-08-2015 12:06 PM
Quick Reply: Traction issues
