Trailblazer T.C. is in! Me like!
Old 08-06-2005 | 10:41 AM
M.Roberts's Avatar
Default Trailblazer T.C. is in! Me like!
Well, finally got it in. Truck really takes off nicely now Install was not bad, but like an idiot I messed up my shift cable so now I have to replace it. I did not know the cable end popped off the arm on the transmisson so I took it apart where the upper and lower halves join and broke the little clip that holds them together and the only way to get a new clip is buy a 100$ cable. Tried every kind of e clip I could get my hands on. No luck. Wound up having to mig weld the cables together so I could get to work. That melted the cable connector plastic housing so I have no Park, have to crank in nuetral. I should have my
Old 08-06-2005 | 11:26 AM
FILE's Avatar
Great.. To what RPM does it brake stall?
Old 08-06-2005 | 12:28 PM
slimcracka's Avatar
yeah what he said^^^ and hows the driving whats it unlock too when ur driving? im really intrested in doin this swap just wanna hear other people that did it and there opinon..
Old 08-06-2005 | 03:14 PM
M.Roberts's Avatar
I tried it on a local road and it brake stalled to about 23-2400 ish before tires started slipping. Otherwise it drives pretty normal seems to be a little more agrresive when it shifts too. I do have a slight surge cruising at about 45 mph I am guessing it is locking unlocking .
Old 08-06-2005 | 03:42 PM
rumblebox's Avatar
after my recent track experience, i DESPERATELY need a different stall.
Old 08-08-2005 | 10:49 AM
M.Roberts's Avatar
what happened?
Old 08-08-2005 | 07:42 PM
rumblebox's Avatar
i stalled it as high as i could, not knowing it pulled more timing with a stock tune. i lost ALL my low end torque. not being able to cool down after a 1 hour drive didnt help either.
Old 08-08-2005 | 07:59 PM
slimcracka's Avatar
what kinda tune are you running. i really need something on the street and track off the line it falls on its face then about 3500 it comes alive.. so somthing cheep and closer to my powerband is what im talking about keep us up to date on this surging and more about the driveing..whats is stall too when driving and giving it eknouf gas to get it to unlock..thanx again for the info..
justin
BROKE-aSS-BLAZER
10-13-2017 04:50 PM
Texas5.3_1251
03-05-2016 09:10 PM
Wolftrk99
10-02-2015 09:17 AM
maxspeed05V
09-23-2015 11:48 AM
RONIN LSX
09-05-2015 11:55 AM
