Tranny dead, should I replace or rebuild?
So my truck for the last little while was grinding a bit, could never tell if it was the tranny, transfer case, or differential. Well last night i got my answer when I felt a large snap and the truck stopped responding to the forward gears and would only go in reverse. I reversed back home for about 1km, luckily I was on a near-deserted campus road). So at this point, no forward going, but reverse working...99% sure must be the tranny. Find this strange as I regularly changed the fluids and the truck only has 210 000km (125 000miles.)
The real problem is that I live in a crowded area, truck is too long for the garage, outside is packed with snow, so chances of me replacing this myself is near zero. So, I've never had a tranny rebuilt before...according to your experiences would rebuilding tend to be a better idea than getting another that's used or is the rebuild cost not worth it? Thanks peeps.
Thanks for the reply guys, I had that idea on my mind. So, can anyone recommend who rebuilds good 4L60E transmissions? There's quite few to select from. I wouldn't mind going with a more reliable transmission that shifts quicker and can handle a bit more power and load. Smooth shifting is not so important to me.
Other option I have, if I can find this... would be upgrading to a 6.0L engine with a 4l80E transmission.
Any suggestions on either idea would be great, thanks!
Well... what do you guys think of this option? http://toronto.kijiji.ca/c-cars-vehi...AdIdZ246101761
ou812sm
07-28-2015 08:24 AM
