Tranny took a crap last night
#41
ok ive been reading this post and i had the same problem almost. after installing my vig 2800 i threw up an ses light. missfire code. caused by the torque converter having to much slippage. this was corrected with edit and now everything is fine. no ses light.
allthough my truck never went into limp mode. but i do have a built tranny. so maybe that had something to do with it.
#42
13 Second Truck Club
From: Pueblo de Nuestra Señora la Reina de los Ángeles de la Porciúncula
What code did you throw Thunder and how did you correct it with Edit?
How hard was it to learn Edit? Did you just go by trial and error?
#44
Originally Posted by Chingon
Yea, I have the B&M cooler, Transgo shift kit and both billet servos...I just need to get rid of TM now...or maybe some of it...I bet my tranny will if I take out all of TM...
TM? That **** is ALL gone from my tranny...
#45
Misfire probably due to the small diameter confusin the computer... small diameter = less rotational mass.
#48
been getting allen from nelson performance to fix it and then comparing files im still learning.
"Test Parameters"
What is your "Torque Converter slip" Normal slip and fail RPM set at?
#49
Under "Transmission Diagnostics"
"Test Parameters"
"Test Parameters"
