Trans Coolers & Deep Trans Oil Pans
Old 10-29-2009, 01:36 PM
SILVERBIRCH's Avatar
Default Trans Coolers & Deep Trans Oil Pans
Well I think I must start adding a little help to my transmission after adding the Cam and Long Tubes I would like to have a peace in mind so I was thinking of adding a Tru-cool 40,000 Trans cooler along with a Hughes Deep Aluminum Trans. Pan. I know many of you guys run one of these I would like to get some feed back on them. Do you guys think this should be sufficient with the mods i have listed in my Sig.
Thanks!!!
Old 10-29-2009, 02:18 PM
Moderators please move to proper section I wasnt paying attention my bad!!!
Old 10-29-2009, 06:17 PM
04SilveradoMykk's Avatar
I've got a Tru-Cool mini-max & Derale deep pan with cooling tubes on my '04 4L60E, I also wrapped the exhaust pipe going under the trans pan with header wrap and used royal purple syn trans fluid
Before, my stall converter used to cook the trans fluid so much you could smell it in the cab. Now my trans temps have not gone above 135 degrees, and usually cruise around town @ 128-130, and I could probably do better if I mount the cooler in front of the Efans too
Old 10-29-2009, 08:07 PM
doesn't know what quit means
lablackbeast's Avatar
were can i get the 40,000 trans cooler???
Old 10-31-2009, 09:51 AM
PT's Slowest Truck
budhayes3's Avatar
I think that a lot of guys get them on ebay...search TruCool 40K...(maybe oregonperformance.com also)
Old 10-31-2009, 10:22 AM
xlcooplx's Avatar
my 40k GVW cooler keeps my trans really cool....so cool that i wouldn't even consider an aftermarket pan
Old 10-31-2009, 10:49 AM
PT's Slowest Truck
budhayes3's Avatar
Yea, the factory deep pan is pretty good...I like some of the aftermarket pans such as the B&M and Hughes, but it appears that clearance would be tight with my y-pipe....
Old 10-31-2009, 10:33 PM
Banned
lucky77's Avatar
tru-cool 40k should do the job.. no need for a deep pan. instead of the deep pan... get a shift kit+servos . they should beef up the tranny.
Old 11-02-2009, 05:53 PM
Thanks for the advice guys
Old 11-02-2009, 09:52 PM
BigRedChvy355's Avatar
+2 on the shift kit/servos.
Quick Reply: Trans Coolers & Deep Trans Oil Pans
