Trans go or B&M Trans pak
#31
The billet servos are easy ... as long as you drop the Y-pipe and make sure you get things in the right order and the right way. They come with instructions .. just follow them.
Am I wrong in assumiing you were saying that you can ALMOST bark the 2-3 shift? If it was the 1-2 shift, that you can ALMOST bark, then that is just right. That's exactly how you want the shifts. Nice, firm, quick, but not to harsh.
The converter will loosen the shifts a little, but not as much as it may sound like. I've got all the small feed holes drilled in the seperator plate, and the bilet servos. If I weren't pushing so much power through it, it would have some stout shifts, but the power tones them down. If for some reason I ever have to drop the valve body I will be drilling out the feed holes a little more.
#32
transgo
yeah i did that myself and it works great kinda got a lil slip last night but not worried yet we will see what happens... but just ordered the servos when they come in i will install them and see what happens do you notice it right away???
#34
CHOP
CHOP
#38
guys around here in my area so its no big deal... but you think i should leave the two spacers out!!!????
Take them out hands down. The 1-2 shifts will be so annoyingly harsh otherwise. I had one in there with the billets and pulled it within a week, MUCH nicer shifts w/o it. They were annoying to me...
#39
Would you consider it a big deal when the tranny goes ?
There are 2 very weak spots when it comes to slamming **** around and shock loads that I can think of right off hand. One would be the steel input shaft in the aluminum drum, the other would be the reaction shell. The welds on it are almost paper then.
Bust the input shaft up and your done .. call the tow truck, break the reaction shell, if your lucky you would prolly have 1st and 3rd, but thats it.
#40
It's all true, the OE internals are about as strong as glass.
