Trans?!?! Why Me!
Old 07-28-2004, 11:10 AM
12 Second Club
O3GMC's Avatar
I called trasgo and one guy said there was no difference between the HD and other kits, just the HD doesnt come with the video or something, and the other kit is for 'do it yourselfers' - didnt make much sense to me....but thats what he said
Mine was slipping in and out of OD about 300 miles after the Transgo, aluminum accumulator pistons and a sevo release check valve were installed.....it only happened once for about 15 minutes then went away, like there was something in there that just got binded up and later fixed itself.....its been fine now for about 500 miles
Old 07-28-2004, 11:16 AM
1TRUESS's Avatar
It was fine right after the install. I did notice that it shifted into OD too soon sometimes.
I also put in the aluminum accumulator piston when I did the install.
Old 07-28-2004, 11:18 AM
BigKID's Avatar
Mine did that exact same thing on the 3-OD-3 a few days after installing my transgo. I just let it be and it cleared itself up. I am assuming some trash got in the valve body from the install. I guess it flushed thru and I havent had a problem since.
The 2-1 problem may be atributed to band clearance. The shims mentioned earlier are the ones that go in the 1-2 servo on the pass side of the tranny. You do not need these if you have a fairly new tranny in good condition. If you installed one or both of these spacers, you band may be catching when not in 2nd gear. Usually you notice it not releasing in 3rd which is were it would bog the motor not in 2nd.
Old 07-28-2004, 11:24 AM
1TRUESS's Avatar
Anyone know how to check band clearance and how to adjust it? I did not put any spacers in the servos, because I did not what it to shift too hard. I have noticed that it releases werid though.
As far as the OD thing, I will just drive around for a little more this week to see if it clears up.
Old 07-28-2004, 01:45 PM
BigKID's Avatar
It tells you in the TransGo instructions how to check the band clearance. Basicly you use a long screwdriver to move the band lateraly on the drum. If it is too tight, it will not move.
I believe you are refering to washers in the 1-2 accumulator. The spacers in question here are about 3" in diameter and go in before installing the 1-2 servo in the side of the tranny on the pass side.
Old 07-28-2004, 01:49 PM
what a rush!
moregrip's Avatar
GM should just put the 4l80e in all trucks, problems solved.
can I get a hell yeah!
a lower 1st wouldn't hurt either
Old 07-28-2004, 07:20 PM
12 Second Club
O3GMC's Avatar
4l65e in all the trucks couldn't hurt either
Old 07-28-2004, 09:08 PM
Black02Z71's Avatar
I think we will have to wait for 2006-2007 when the new six speed autos come out. Production starts in 2005 for 2006 models (not sure what will get it first).
Old 07-29-2004, 12:39 AM
1TRUESS's Avatar
OK! Drove the truck to work and back, took the highway, and the trans seems to be fine now! WTF! I am not complaining. Maybe it was just a particle working its way threw the valve body. I am not worried any more.
Old 07-29-2004, 11:15 AM
12 Second Club
O3GMC's Avatar
awesome man, I had a feeling it would go away - sounded just like my problem and mine is fine now
Texas5.3_1251
03-05-2016 08:10 PM
CammedZ71
11
09-09-2015 02:05 PM
11MPG
09-08-2015 04:52 AM
Mark_k
09-07-2015 10:15 PM
MadDMax66
09-05-2015 01:27 AM
Quick Reply: Trans?!?! Why Me!
