Transmission Question
ratios
Originally Posted by James B.
The TM reduces power by retarding timing during the shift, yes. That's what what is showing up on your logs. What we are really talking about here is the lack of power at the bottom of second gear after the shift due to the huge difference in ratio between the 3.059:1 first gear and 1.63:1 second gear. Every vehicle with a stock converter and a 700R4/4L60E will experience this to some degree.
Originally Posted by john kilgore
would 2.66-1.50 be any better?
This is a very, very interesting thread for me.
My 2nd gear just went out and I am looking to have my transmission rebuilt.
I sometimes tow a small car (3500lbs) and am curious about transmission upgrades, but I simply cannot do something that will compromise the reliability of the transmission ...
Any suggestions? At this point, I am seriously considering a stock-rebuild.
thanks,
Chris
thanks,
Chris
would need a tranny cooler and i agree i have a 3k converter and wish i would have went higher so once you get one you will want a bigger one doesnt matter what size you get . i recommend the GM coolers i have heard they are the easiest to install and you cant go wrong with GM especially if someone has to work on it and starts snoopin around
zblee
63
06-10-2023 01:25 PM
thewrx
08-12-2015 08:28 PM
