Trick Flow camshafts?
Has anyone here used trickflow camshafts yet? These are a bargain compared to other existing cams out there at only $269.99 a piece. Quality I'm told I shouldn't worry about since they are Lunati blanks which are ground by Lunati as well. I am building a 6.0 that will be completely stock for a rcsb 2wd truck. I am wanting to do cam and headers only. The 2 trickflow cams I was looking at are:
Product Line: Trick Flow Track Max Camshafts for GM LSX
Part Type: Camshafts
Cam Style: Hydraulic roller tappet
Basic Operating RPM Range: 2,000-6,000
Intake Duration at 050 inch Lift: 216
Exhaust Duration at 050 inch Lift: 220
Duration at 050 inch Lift: 216 int./220 exh.
Advertised Intake Duration: 330
Advertised Exhaust Duration: 330
Advertised Duration: 330 int./330 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.560 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.560 in.
Valve Lift with Factory Rocker Arm Ratio: 0.560 int./0.560 exh. lift
Lobe Separation (degrees): 114
Intake Valve Lash: 0.000 in.
Exhaust Valve Lash: 0.000 in.
Computer Controlled Compatible: Yes
Quantity: Sold individually.
Notes: Computer modifications recommended for best performance.
Camshaft, Track Max, Hydraulic Roller Tappet,Advertised Duration 330/330,Lift .560/.560,Chevy,Small Block,Each
Or the
Basic Operating RPM Range: 2,500-6,300
Intake Duration at 050 inch Lift: 220
Exhaust Duration at 050 inch Lift: 224
Duration at 050 inch Lift: 220 int./224 exh.
Advertised Intake Duration: 338
Advertised Exhaust Duration: 338
Advertised Duration: 338 int./338 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.575 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.575 in.
Valve Lift with Factory Rocker Arm Ratio: 0.575 int./0.575 exh. lift
Lobe Separation (degrees): 112
Has anyone used either of these camshafts, if so did you like them? Otherwise how do you think these would perform? I can't see where spending another $130 on a comp or thunder racing cam would be beneficial. If anyone has used either of these, do you have soundclips?
Thanks
Or the
Thanks
I was also looking at these cams but one thing i would look at is they recommend 10.5-1 compression. You would definetly want a stall with the bigger of the two seeing the rpm range, lunati does have a good rep so for the money it should be worth it.
I was looking more at the @ .050 numbers more than anything. That's gotta be a mistake, not even the highest comp solid roller cams have an advertised duration that high. Although I did copy and paste the information directly from trick flow's website. A phone call will be in order to TEA in the morning as I will more than likely be buying from them. Here is a super write-up I found over on tech about the trickflow cams. https://ls1tech.com/forums/showthrea...t=#post5446951 Those power curves look absolutely astonishing. On stock heads, a guy should be able to mimick those power curves, they just won't be as "intense".
those curves do look good, 220 cam looks like it would work out nicely, maybe even advance it a few degrees. That kinda power seems like its high for the mods but curves nicely.
thompson
12-27-2017 06:48 AM
