Trouble codes after LT install
Moderately Differentiated
Do you have a wideband gauge?
Cat efficiency codes after a header install and high flow cat install. As well as misfire codes. Ugh, you are really getting hit huh? Get on your back and make sure you didn't nick, cut, burn, or damage ANY of the 02 sensor wires. Unplug them and make sure the connection is good. None of them are pinched are they?
Misfires are an oddity as they can relate to a ton of things as I am sure you know, but you have to look around your header install very carefully. No leaks, nothing...just a nice tight install. I am guessing you unplugged all your spark plugs for the install...make sure you plugged them back GOOD. A misfire after a header install is almost certainly related to those plugs. Crack a spark plug? Didn't get the coil plug all the way in?
I was very thorough and even removed all plugs as to not damage them. I did throw a code that specificly showed #1 misfire I replaced that plug and the wires are new after the install. I also threw multiple random misfire...is this more than one cylinder misfiring or one cylinder with multiple misfires? It may just be a problem with #1 that needs to be figured out.
If your wires are even slightly touching the header tubes, they will burn a small hole pretty quick causing electrical arc and the random misfire code. This happened to my MSD wires when I did my long tubes. I had to bend them where they snap onto the plug so they weren't touching the long tubes.
That's what I've been trying tell yall... damn new headers melted my wires and I bought some heat retardent sleeves for the wires. I also mentioned if you'd like the link for where I purchased them, PM me.
I learned from my shortie install to watch the wires. i burned like three wires on the first test run. With the long tubes I put new wires and made sure to bend them correctly. If I drive civil I pull no codes at all. For the past two days no codes but never got on it at all. if I go WOT I get the codes.
