Truck doesn't start after cam install help..
Old 10-28-2013, 02:00 PM
  #21
Yukon04's Avatar
Crank sensor wire is pulled out......
Old 10-28-2013, 02:01 PM
  #22
TXsilverado's Avatar
not going to start without that sensor plug it in and fire it up.
Old 10-28-2013, 03:02 PM
  #23
Yukon04's Avatar
A wire was cut... From that connector
Old 10-28-2013, 08:11 PM
  #24
running now?
Old 10-28-2013, 08:13 PM
  #25
Yukon04's Avatar
It is... Two problems one fans come on instantly two runs like ****... I installed a gt7 cam I figured it would be ok without a tune for now since it's not a big cam guess not.
Old 10-28-2013, 08:59 PM
  #26
what size is that cam? i cant keep up with all of the cam pet names.
Old 10-28-2013, 09:39 PM
  #27
Yukon04's Avatar
208/230 550/552 121lsa
Old 10-28-2013, 11:45 PM
  #28
cdub81's Avatar
On the grounds, there is one that connects on the pass top side of block...
Then the drivers side back of block by bell housing
On the fan/idle shitty, could be as simple as idle airflow adjustment since you've changed cam/heads etc. Yea you can run it but it needs some tuning
Old 11-09-2013, 01:33 PM
  #29
RangerDan's Avatar
I just did a TSP 220R (220/220 .581/.581 112 LSA) swap and a DOD delete, no tune but it heats up and runs hot now because its running way lean. I won't be driving it any length of time or distance until I get it tuned just to save that kind of heat shock on the internals.
Dan
all_individual
10-10-2015 10:09 PM
chevyl33
08-24-2015 08:21 AM
cams 98 silverado
07-31-2015 07:36 AM
all_individual
07-13-2015 11:01 AM
chevy1224
07-13-2015 07:50 AM
Quick Reply: Truck doesn't start after cam install help..
