truck getting hotter after 180 thermostat install
I installed a 180 degree thermostat on my truck and the engine temp gauge is showing hotter than it did when I had the stock thermostat. The a/c compressor is cycling on and off repeatedly too. And last but not least, my E-fans aren't coming on now like they were with the stock thermostat.
I've heard some guys say that the radiator needs to be "bled" of air.
Is this what's causing the overheating?
If I need to bleed the radiator, what's the best way since there's no drain plug on the radiator?
I'm thinking maybe to loosen the thermostat housing and let the coolant run out that way.
PT's Slowest Truck
If you have an air pocket, you should be able to burp it out yourself....some guys run the engine through a heat cycle and let it cool down then refill the reservoir, and do this a few times. I've had luck with grabbing the upper rad hose and sqeezing...you will actually hear the coolant burp and bubble in the overflow. Then I top off and repeat several times until the burping stops.
Adkoonerstrator
There is a procedure for clearing air pockets outta the cooling system. I posted it in here one time, let me see if I can find it.
One other thing. Just because you have a 180 degree thermostat doesn't mean your ECT will run at 180.
FormerVendor
Sure does sound like an air pocket to me, I had one so bad when I did a tstat change my temp gauge went into the red for a few seconds.
When I had a 160 tstat in mine it ran about 180 so I don't know how much cooler your engine will run with a 180 vs the stock thermostat.
